Date/Time: Thu, 06 Feb 2025 12:23:27 +0000
Need help with an order
View Count: 563
[2020-04-27 17:42:21]
rainbow47 - Posts: 68
I am using the Spreadsheet Trading System. The system enters the trade without a limit or a target.
I would like to raise a stop order automatically once the price is 20 ticks up with an offset of 12 ticks. Or in other words 3 points below current market level or 2 points above my entry level (long position) once the price is up 5 points.
Is that possible?
Date Time Of Last Edit: 2020-04-27 17:43:32
[2020-04-27 20:07:52]
Refer to the documentation here for this:
Spreadsheet Systems, Alerts and Automated Trading: Initiating Trades with Auto-Trading and Using Manual or Attached Orders Exits
[2020-04-27 20:15:53]
I did but read it it is still not clear to me how to achieve it. It's not clear to me with which parameters I have to set up the AO order.
[2020-04-27 20:17:41]
Refer to the documentation here for Attached Orders:
Attached Orders
[2020-04-27 20:22:04]
Trust me, I read your user manual before I post a question. I still don’t know how to configure the AO to achieve the objective.
[2020-04-28 19:33:56]
With Attached Orders the Stop order will be submitted with the Entry order. There is no support to submit it later. You just add one Stop order to the Attached Orders and then you can set it to move to breakeven plus an offset:
Instructions:
Attached Orders: Using Attached Orders and Attached Order Settings
And here are the Move to Breakeven for Stops instructions:
Attached Orders: Move to Breakeven for Stop
Date Time Of Last Edit: 2020-04-28 19:34:11
