Date/Time: Thu, 06 Feb 2025 11:51:36 +0000
Recommended Futures Brokers and guidance.
View Count: 2577
[2020-04-27 16:44:09] |
theunknowntrader - Posts: 112 |
I currently trade equities using DAS Trader platform but am transitioning to futures. My broker is interactive brokers but from what I am reading, IB is not recommended if you want to trade futures using Sierra Chart. So questions: 1. What is the best top notch broker you recommend to use with Sierra Charts? 2. Can I connect two different brokerage accounts to Sierra Charts? a) IB brokerage to trade equities b) second broker to trade futures? |
[2020-04-27 20:09:20] |
1. We do not recommend brokers, but we do recommend using this order routing service which supports many brokers/clearing firms: Sierra Chart / Trading Technologies Futures Order Routing Service 2. Yes by using two separate installations of Sierra Chart. Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
