Date/Time: Wed, 27 Nov 2024 20:37:27 +0000
[Programming Help] - Compiling Error
View Count: 1538
[2020-04-27 14:52:26] |
User247273 - Posts: 37 |
I downloaded the source code for the COT study from here. https://www.sierrachart.com/AdditionalFiles/UserContributedACS_SourceCode/COT.cpp Then I followed these instructions for building a custome study from source code. How to Build an Advanced Custom Study from Source Code However. I'm getting an error after I click Remote Build to compile the study. I'm running version 2086. The text of the error is pasted below. TEXT OF ERROR -- Starting remote build of Custom Studies Source files: COT.cpp. 64-bit -- 09:51:14 Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: COT.cpp:2:30: fatal error: scstudyfunctions.h: No such file or directory #include "scstudyfunctions.h" ^ compilation terminated. -- End of Build -- 09:51:16 |
[2020-04-27 15:43:14] |
UPDATE: I changed the following line of code: #include "scstudyfunctions.h" to read #include "SCStudyFunctions.h" That led to a new error. ERROR TEXT -- Starting remote build of Custom Studies Source files: COT.cpp. 64-bit -- 10:42:38 Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: COT.cpp: In function 'void scsf_TradingLevelsStudy(SCStudyInterfaceRef)': COT.cpp:299:29: error: conversion from 'SCString' to non-scalar type 'std::__cxx11::string {aka std::__cxx11::basic_string<char>}' requested std::string Bufferas = sc.HTTPResponse; ^ COT.cpp:335:29: error: conversion from 'SCString' to non-scalar type 'std::__cxx11::string {aka std::__cxx11::basic_string<char>}' requested std::string Bufferas = sc.HTTPResponse; ^ -- End of Build -- 10:42:42 |
[2020-04-27 15:52:14] |
User907968 - Posts: 823 |
You could try this instead: std::string Bufferas = sc.HTTPResponse.GetChars()
[2020-04-27 16:47:05] |
Thanks. Problem solved with some help from a friend. I changed the 2 instances of std::string Bufferas = sc.HTTPResponse; to std::string Bufferas = ""; Buffer.Append(sc.HTTPResponse); |
[2020-06-20 09:44:42] |
User330484 - Posts: 2 |
Hi, I get this error when compiling the cot.cpp file -- Starting remote build of Custom Studies Source files: COT.cpp. 64-bit -- 11:40:23 Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: COT.cpp: In function 'void scsf_TradingLevelsStudy(SCStudyInterfaceRef)': COT.cpp:299:29: error: conversion from 'SCString' to non-scalar type 'std::__cxx11::string {aka std::__cxx11::basic_string<char>}' requested std::string Bufferas = sc.HTTPResponse; COT.cpp:335:29: error: conversion from 'SCString' to non-scalar type 'std::__cxx11::string {aka std::__cxx11::basic_string<char>}' requested std::string Bufferas = sc.HTTPResponse; COT.cpp:427:43: error: ambiguous overload for 'operator-' (operand types are 'SCDateTime' and 'double') SCDateTime DataDateLessOne = DataDate - 1*DAYS; COT.cpp:427:43: note: candidate: operator-(double, double) <built-in> In file included from scstructures.h:98:0, from sierrachart.h:21, from COT.cpp:1: scdatetime.h:1506:19: note: candidate: SCDateTime SCDateTime::operator-(const SCDateTime&) const inline SCDateTime SCDateTime::operator -(const SCDateTime& DateTime) const -- End of Build -- 11:40:26 Who can help? thank you |
[2020-09-19 21:16:35] |
rxtrading - Posts: 33 |
I am having a similar issue as indicated above. -- Starting remote build of Custom Studies Source files: COT.cpp. 64-bit -- 16:09:38 Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: COT.cpp: In function 'void scsf_TradingLevelsStudy(SCStudyInterfaceRef)': COT.cpp:427:47: error: 'DAYS' was not declared in this scope 427 | SCDateTime DataDateLessOne = DataDate - 1*DAYS; | ^~~~ -- End of Build -- 16:09:42 Did anyone find a solution for this issue? |
[2020-09-19 21:28:25] |
ForgivingComputers.com - Posts: 960 |
The error is here on line 427: SCDateTime DataDateLessOne = DataDate - 1*DAYS;
Change it to: SCDateTime DataDateLessOne = DataDate - SCDateTime::DAYS(1);
This was documented as a change here: Required SCDateTime Changes for ACSIL |
[2020-10-21 16:19:13] |
User616224 - Posts: 6 |
Hello, I followed your instructions, I corrected all the mistakes and finally I have successfully compiled the COT, but it still doesn't work. There's a log in Sierra that says: "requesting data from quandl server". Don't you please know what's the problem? |
[2020-10-21 16:33:31] |
Ackin - Posts: 1865 |
Study accesses COT data from Quandle.com ( basic free account needed for study )
[2020-10-21 16:41:10] |
Personally, I also had difficulty getting this study to work. After I finally did, it didn't give the data I was looking for. I use IQFeed and get the CoT data from them. Additionally, they have a lot more history.
[2020-10-21 16:48:21] |
I do have Quandle.com account and Quandl APIkey, but it doesn't work anyway.
[2020-10-21 17:26:04] |
So try to contact the author of the study via DM (or email) COT / Commitment of Traders | Post: 170793 |
[2020-10-21 17:29:00] |
I know...It's a pity that this is not possible (even for an additional fee) within the Sierrachart datafeed
Date Time Of Last Edit: 2020-10-21 19:53:31
