Date/Time: Thu, 06 Feb 2025 11:19:16 +0000
Denali April 30 expiration
View Count: 493
[2020-04-27 14:15:17] |
abrown8703 - Posts: 64 |
SC, I am a bit confused. I am currently subscribed to the Denali feed @ $25 per month with market depth. However, I would like to subscribe to the 3.25 option with no market depth as of May 1. Do I need to do anything prior to Friday, since I have contacted you about this prior?
[2020-04-27 17:25:27] |
No, that exchange will not renew. Next month, and make sure that you are into the new month by hours, you can then activate the new exchange: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
