Date/Time: Mon, 16 Sep 2024 19:20:26 +0000
[User Discussion] - Change Background Color on Alternate Days.
View Count: 1486
[2014-01-16 20:55:29] |
User94614 - Posts: 13 |
Is it possible to change the Background Color slightly on Alternate Days so day Start/End is obvious?
[2014-01-16 21:22:55] |
Sawtooth - Posts: 4091 |
You could use the Color Background Based On Alert Condition study, with this formula on the Alerts tab: =ISEVEN(BARDATE) This works if Sundays are excluded. If Sundays are included, you could color them differently using another instance of the Color Background study with this formula: =WEEKDAY(BARDATE)=1 |
[2014-01-16 23:04:12] |
Thanks, I tried it and it fails when there is a Monday holiday because Tuesday and Friday both have even or odd dates. If I could use the bar number instead of the date it should work or if KI could test for the previous day's backgroud color. |
[2014-01-16 23:52:02] |
OK, You can do what you want with the Spreadsheet Study study. -Put this formula in cell K3: =ISEVEN(O3) -Put this formula in cell O3: =IF(INT(A3)>INT(A4),O4+1,O4) -Set the Draw Style of K(SG1) to Background |
[2014-01-21 12:45:37] |
Thanks, I got that to work.
