Date/Time: Thu, 06 Feb 2025 10:52:04 +0000
Study Angle
View Count: 787
[2020-04-25 00:09:19] |
User1967 - Posts: 34 |
Hello, I couldn't put the study "Study Angle" to work. I am trying to calculate angle of a subgraph (attached picture #1, PPO line (Region 2) and the study angle is displayed in Region 3. The documentation says that the angle is given in degrees but it shows the angle as 1.7138 which is not correct. The settings are displayed in Picture 2. Even if it is in radians then the value is incorrect. Please advise how to calculate the angle of a subgraph such as PPO Line in this case. Regards, |
Sierra Study Angle Pic 1.png / V - Attached On 2020-04-25 00:08:08 UTC - Size: 165.22 KB - 369 views Sierra Study Angle Pic 2.png / V - Attached On 2020-04-25 00:08:16 UTC - Size: 32.56 KB - 318 views |
[2020-04-26 10:46:31] |
You need to reduce the Value Per Point input. Refer to the description here for this: Study Angle You probably want to use something like .05 or smaller. You really just have to use your own judgment on that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-26 10:50:42
