Date/Time: Mon, 25 Nov 2024 17:40:20 +0000
How to start trailing stop after target has been filled?
View Count: 940
[2020-04-24 21:47:42] |
User269983 - Posts: 31 |
I need help setting a 3 targets strategy. Example, Target 1 = 20 ticks Target 2 = 40 ticks Target 3 = 100 ticks Stop = 50 ticks 1) When target 1 is filled, stop move to 25 ticks 2) when target 2 is filled, move to stop to BE 3) After target 2 is filled, trail the stop every 10 ticks. I got step 1 and 2. But I cannot figure out 3. I just cannot SC to trail only after the target is filled. I have tried using step trailing, but it trails all the time. Thank you. |
[2020-04-27 19:15:01] |
3. Use the Triggered Step Trailing Stop: Order Types: Triggered Step Trailing Stop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-13 23:48:32] |
User467500 - Posts: 27 |
could you pls share the OCO you created for the 3 target strategy?
