Date/Time: Thu, 06 Feb 2025 13:41:08 +0000
Historical NISS-NYSE
View Count: 759
[2020-04-24 18:34:43] |
coachted - Posts: 347 |
how do i get historical NISS-NYSE info for chart... I have created an intraday continuous chart for ES and want to have the NISS-NYSE ass an added symbol and yet it does not back fill the info for the NISS-NYSE please advise...Id like the NISS-NYSE to show as a line not a candle stick but I do have the ES in Candle sticks is this possible? In addition I would like it to be a continuous line from close to open from day to day...how do i do that? Date Time Of Last Edit: 2020-04-24 18:57:04
[2020-04-25 07:17:31] |
First open a chart for NISS-NYSE and make sure you have all of the data. If not, refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart And then refer to: Sierra Chart Market Statistics: Overlaying a Chart on Another Chart as a Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-25 12:06:49] |
how do i make the NISS-NYSE a line rather than a candlesticks...it is an additional symbol on an ES chart which is canclesticks
[2020-04-27 14:29:56] |
John - SC Support - Posts: 37769 |
You need to change the Graph Draw Type to what you want. This is located at the top of the Subgraph tab of the Settings window for the Add Additional Study. Refer to the information here: Chart Studies: Subgraphs Tab >> Graph Draw Type For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-29 20:04:03] |
in addition: Is there a way just to show yesterdays hi low POC valua area low and value area hi on a day numbers bar chart? Is there a way just to show the overnight session hi low and POC on a day numbers bar chart? |
[2020-04-29 21:36:10] |
Have a look at these studies: TPO Value Area Lines High/Low for Time Period - Extended Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-30 01:47:54] |
Im sorry my question wasn't cleare...I am using a numbers bar chart and I want to show both the POC, Value area high, value area low for the overnight session and the POC, Value area high, value area low for the day session is that possible. This should yeild 2 POC's, 2 Value area highs and 2 Value area lows
