Date/Time: Mon, 25 Nov 2024 04:54:06 +0000
Merging MA's from several charts
View Count: 1041
[2014-01-16 16:12:20] |
User44323 - Posts: 26 |
Is there a way to draw in moving averages from several charts into one panel? Thank you |
[2014-01-16 17:11:54] |
Yes. Refer to help topic 28 here: http://www.sierrachart.com/index.php?l=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
