Date/Time: Thu, 06 Feb 2025 10:48:18 +0000
AMP Trading Account
View Count: 1231
[2020-04-24 14:42:17] |
bluestar - Posts: 4 |
Good Morning, I searched support board and could not find my answer, but doesn't mean it is not there somewhere on the support board. Anywho, I have a funded account with Amp trading, they are the ones that suggested I try your TPO charts, which are better than I expected for my needs. So, I am reading about TT as a feed but , when I plug in Sierra charts in the AMP Commission Calculator it will not match as a feed only CQG for a package 5, 25.00 per month. So, is this lag thing a deal with the feed or I am missing something? I trade off the Jigsaw DOM so do not need to trade off your chart but need the real time TPO charts to match my DOM for my levels. Not sure what I should do for the problem. I monitor the EPM20, CLEM20, USAM20, and the TYAM20 products. Thank you Mark |
[2020-04-26 11:33:28] |
So you are using CQG for Jigsaw? You cannot use that account for data for Sierra Chart without paying exchange fees again. The proper solution to this is as follows: Have AMP set you up with the TT account with a 100 USD account balance: Easy Solution to CME Funded Trading Account Requirement Use the Denali exchange data feed: Denali Exchange Data Feed The exchange fee will just be 3 USD amount plus the connection for 20 USD a month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
