Date/Time: Thu, 06 Feb 2025 10:18:04 +0000
where can I find the actual formulas syntax of standard studies?
View Count: 544
[2020-04-24 13:57:03]
PaulC - Posts: 16
where can I find the actual formulas syntax of standard studies? for educational purpose?
Date Time Of Last Edit: 2020-04-24 14:07:41
[2020-04-24 14:16:29]
Ackin - Posts: 1865
Technical Studies Reference
Some studies do not have a simple formula. There are whole blocks of the program (eg with loops or returns in memory for another calculation). If you want to do this exactly, then all you have to do is look at the code in the ACS_Source folder in Sierrachart.
Date Time Of Last Edit: 2020-04-24 14:22:53
