Date/Time: Wed, 12 Feb 2025 07:22:24 +0000
TPO profiles - Tab name too long
View Count: 753
[2020-04-24 10:18:48]
User365411 - Posts: 192
rel 2092 from rel 2086
Using a custom Title Bar Name with the "Display Chart Timeframe On Tabs When Title Bar Name Is Set To Be Used On Chart Tab (Global Settings >> General Settings >> General 2)" on a chart with a a TPO study result in a very long name tab.
In a chartbook with multiple TPO charts and other standard bar charts makes browsing through the tabs impractical.
Please can you resolve this problem and roll back to the usual visualization?
TY
Date Time Of Last Edit: 2020-04-24 10:19:31
imagexSierra Chart MainWindow 2020-04-24 12_12_52.393.png / V - Attached On 2020-04-24 10:17:39 UTC - Size: 97.34 KB - 253 views
[2020-04-24 18:22:56]
We will resolve this.
[2020-10-11 17:34:33]
rel 2179
Please can you check that problem? It's not solved at the moment.
TY
Date Time Of Last Edit: 2020-10-11 17:37:08
[2020-10-12 21:35:19]
Provide a screenshot showing what you are seeing.
[2020-10-13 07:08:45]
It's already in first post, anyway this is taken from release 2180.
imageSierra Chart MainWindow 2020-10-13 08_59_20.532.png / V - Attached On 2020-10-13 07:08:18 UTC - Size: 60.39 KB - 192 views
