Date/Time: Thu, 06 Feb 2025 09:54:25 +0000
ReduceOnly setting for BitMEx - possible on a per order basis in current version?
View Count: 670
[2020-04-24 01:23:02] |
Zebbity - Posts: 18 |
I see you guys have implemented ExecInst execution instructions for BitMex connections at the Data/Trade Service Settings Level. That seems to imply to me that I will not be able to programmatically implement ReduceOnly on a per order basis within your trade automation systems such as ACSIL and the spreadsheet? Please confirm? BTW, thank you for implementing leverage settings for BitMex. That didn't exist the last time I used Sierra. |
[2020-04-24 07:50:20] |
Yes your understanding is correct.
