Date/Time: Thu, 06 Feb 2025 09:46:47 +0000
Slow stochastic indicator request
View Count: 682
[2020-04-23 18:39:11]
User220914 - Posts: 239
HI,
Had a request for the stochastic indicator. IT allows us to set 2 lines at different levles from 1 to 100 and
i set for default 70 /30. Would it be difficult to set one at 50 or allow us to have 1 more line to set so we would
have 3 line levels. thank you if this is possible and understand if low priority.
thanks
[2020-04-23 21:24:16]
Ackin - Posts: 1865
Just for visualization?
You can use Study "Line" from the default Sierrachart list
Line
If you have another reason (alerts or .....), log in to the CZSK forum and I will make it and place it for download there.
contact link:
[2020-04-23 22:08:55]
good call thanks and yes just visualization
[2020-04-24 04:14:07]
Refer to the documentation here for this:
Chart Studies: Adding a Horizontal Line to an Existing Study
Just add the Horizontal Lines study and add the 50% line in there. Just make sure that this study is displayed in the same region as the Stochastic - Slow.
