Date/Time: Thu, 06 Feb 2025 10:17:04 +0000
Lag experiencing when logging to Sierra Charts from Infinity AT
View Count: 608
[2020-04-23 18:24:04]
KK001 - Posts: 4
My setup is - got Sierra Charts from Infinity and so logging in Sierra from Infinity AT.
When I look at the countdown timer and the price movements on Sierra, I realize that there is lag in the price movements and the countdown time jams anywhere from 3-10 seconds. Not sure if it makes a significant difference, but it is certainly annoying to see those type of jumps. Internet speed greater than 300MBPs and new machine with SSD drive - so hardware and network should not be an issue.
If anyone with similar setup has experienced and resolved it, would greatly appreciate some insights.
Thanks,
Kal
[2020-04-23 22:18:31]
You are getting your data from TransAct. We recommend using one of the Real-Time Data Feeds from Sierra Chart. You can learn more here:
Real-Time Exchange Data Feeds Available From Sierra Chart
