Date/Time: Thu, 06 Feb 2025 09:34:39 +0000
Daily P/L reset time does not take the chart time zone into account
View Count: 547
[2020-04-23 16:58:53] |
Martin168 - Posts: 1 |
I think there is a bug in the calculation of the reset time for the Daily P/L values. It is wrong if the time zone of the chart is different from the global time zone. In my case, the global time zone is CET and the chart time zone is ET. The chart trading session is from 18:00 to 17:59 ET (no evening session). I would expect that the Daily P/L is reset around 18:00 ET. However, it is reset at 18:00 CET (= 12:00 ET) - in the middle of the trading session. This happens both in Sim trading and real trading. SC version is 2091. I have read the documentation: Help With Daily Profit/Loss Value |
[2020-04-23 21:22:27] |
We will check on this. This also explains a similar issue that someone else reported and we could not understand why it was happening in their case.
[2020-04-24 03:56:37] |
We did discover what the problem is and it is now resolved. We will have version 2092 out later today.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-24 03:56:55
