Date/Time: Thu, 06 Feb 2025 18:15:21 +0000
SC Historical Data
View Count: 564
[2020-04-23 16:55:10] |
tehmonst4r - Posts: 3 |
Hello, Is it possible to mirror the historical data on an external server to perform analytics? If not, how can one get data from Sierra chart into analysis software such as MathLAB or Excel? Andrew |
[2020-04-24 03:40:30] |
There are various export commands available on the Edit menu: Edit Menu Also refer to: Exporting and Importing Intraday Data Files: Alternative Ways to Export Data Daily Historical data files are already in a Text format, so those can be opened directly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-24 03:43:54
[2020-05-05 15:39:10] |
Is there an API available to connect to in order to avoid having to manually export all of the data from the platform?
[2020-05-06 08:31:09] |
Yes refer to: Data and Trading Communications (DTC) Protocol Server Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
