Date/Time: Thu, 06 Feb 2025 09:08:08 +0000
problem with the NPL while using simulated trading
View Count: 586
[2020-04-23 13:47:39] |
User72436 - Posts: 10 |
For 7-10 days I have had inaccurate profit/loss while trading 1 minute chart on May, June and July crude contracts. I enter with 3 lot trade with stops at 8 ticks and targets at 8, 15,and 25 ticks. The problem is instead of my max loss per trade at $240 it will often register in the NPL that I lost $7000-8000 and my fills on these where $2.00 from where my bracket had placed them. I then clear trade simulation orders and data and start over but it repeats. It gives me accurate totals for a while and then the $7500 surprise. I have Version 2087 64-bit (30871) and using data from Transact. I have also closed Sierra and re-opened multiple times and could not find solution in the Sierra table of contents. Thanks |
[2020-04-23 21:44:58] |
Refer to this page: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
