Date/Time: Thu, 06 Feb 2025 10:00:38 +0000
Bar Difference study
View Count: 669
[2020-04-23 10:32:45] |
User33743 - Posts: 83 |
Hello, I am using Bar difference study with Text display for study to see "Candle size". With indices, energy works fine but currencies study shows some random number after decimal point, could you check that? Screen at the attachment. Best REgards |
[2020-04-24 04:06:57] |
Make sure you have the Value Format of the Bar Difference study set to match the number of decimal places for the Forex pair that you are viewing. Refer to the following for this setting: Chart Studies: Settings and Inputs Tab >> Value Format For further support you need to log into this support board with your active Sierra Chart account. You can do that with Help >> Support Board. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
