Date/Time: Thu, 06 Feb 2025 10:50:00 +0000
Daily change % & Quote Board
View Count: 1367
[2020-04-23 09:42:30]
User263774 - Posts: 5
How can I get the same percentage from my Quote Board (daily change%) to a chart?
Indeed I notice that I do not have the same percentage.
I use on my graph "Percent change since open"
Thanks for your help.
[2020-04-23 09:57:28]
You need to add the corresponding field through the Chart Header:
Global Settings Menu: Customize Chart Header - Standard (Global Settings menu)
[2020-04-23 10:19:11]
Thank you for you feedback.
I followed your instructions well and it works.
But that does not answer my problem because I misspoke my need.
You will find attached an example of what I am looking for.
Many thank
imagedailychangevsquoteboard.png / V - Attached On 2020-04-23 10:18:52 UTC - Size: 299.32 KB - 318 views
[2020-04-23 19:58:03]
User135370 - Posts: 162
I think I posted something similar, is there a way that I can overaly the ES Daily percentage change over a ZB chart for example. Currently I am also using Percentage change since open and then overalying it on the ZB chart using Text Display for study from chart but obviously it is not the same value that is found on the quote board. Appreciate there may not be a way round this at the moment because of the way the daily change is claculated differs from the data feed (I use Denali)
[2020-04-23 20:59:17]
In regards to post #3, there is not a way to do what you want.
[2020-04-23 21:29:24]
And post 4? Is there a way I can know more about how the settlement price is calculated on Denali feed? That would fix my issue
[2020-04-23 21:42:03]
You will need to ask the exchange that question. Refer to:
Getting Quotes: Field Descriptions
[2020-04-27 04:39:10]
It is not possible to have a correct chart in %, too bad..
[2020-04-27 05:30:33]
I got it very close on the ES use 15:15 as your settlement price. It’s difficult to get it exact because the Way it is calculated by CME. For me I just need to see the up and down ticks so percent change since open study will suffice because I get that info regardless of the discrepancy I’m just happy to have it so close by changing session times.
