Date/Time: Thu, 06 Feb 2025 08:38:53 +0000
Connect to FIX TT
View Count: 842
[2020-04-22 21:34:00]
User148596 - Posts: 217
Hi I was told I was connected to the TT FIX feed but when I click on it in the Data/Trade Service settings window and select TT FIX from the dropdown menu it says: TT FIX (not enabled in package)
Please advise.
[2020-04-23 03:18:30]
You will not use TT FIX directly. You need to follow the instructions here:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
Date Time Of Last Edit: 2020-04-23 03:18:38
