Date/Time: Thu, 06 Feb 2025 08:11:07 +0000
multiple monitors and RAM
View Count: 637
[2020-04-22 16:37:44] |
taipeicity - Posts: 52 |
Hi I use sierrachart on my laptop with Two 21"external monitors do I need to increase RAM so can use charting smoothly without dragging? |
[2020-04-22 18:47:42] |
We cannot say whether you need more memory in your system or not. In general, refer to the following regarding performance: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.48 - Basic Steps to Resolve Performance Issue in Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-22 18:48:18
