Date/Time: Thu, 06 Feb 2025 09:17:34 +0000
Numbers of Pricelevels in DOM
View Count: 603
[2020-04-22 12:42:59]
nicktrader - Posts: 734
Is it possible to increase the number of Pricelevels in the Trading DOM. At the moment the FDax is very volatile and if you want to set a TP of 100P(200T) it is not possible.
Txs
[2020-04-22 18:18:28]
Yes what you do is use Interactive Scale Range to increase the range of prices:
Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale
[2020-04-22 22:20:47]
seandunaway - Posts: 316
Nick, this might be helpful: Price Consolidation on TradeDOM
(gist: try adjusting the Tick Size and Currency Value per Tick to something more manageable)
Date Time Of Last Edit: 2020-04-22 22:24:41
