Date/Time: Thu, 06 Feb 2025 08:08:48 +0000
Quote Board information
View Count: 837
[2020-04-22 11:40:46] |
jsmanuse - Posts: 32 |
I use the quote board for alerts and watching specific fields, however I have found that when I close the quote board and reopen it after saving it, it will retain the securities, currency pairs etc, but it will not retain the set fields so they have to be reset on opening. It would be a great fix for the platform in an upcoming version to avoid a work around where you have to just leave it open all the time... thanks.
Attachment Deleted. |
[2020-04-22 11:59:13] |
You do have to keep it open but you can minimize it.
