Date/Time: Thu, 06 Feb 2025 07:55:56 +0000
Window minimization
View Count: 504
[2020-04-22 05:17:34] |
User169391 - Posts: 62 |
Not sure if this is an issue or something local to my computer. Does anyone else find that on chart windows, after doing changes to studies that on applying the changes the window will minimize and then has to be restored. I run windows 10. Is this normal behaviour for detached windows? Is there a setting I am not aware of. Ta.
[2020-04-22 07:56:03] |
This sounds like some strange Windows 10 behavior. We do hear about occasional odd behaviors. It certainly is not anything Sierra Chart is doing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
