Date/Time: Fri, 18 Sep 2026 09:29:33 +0000
Ctrl-MouseWheel to expand / contract candles at mouse pointer.
View Count: 1780
[2020-04-21 23:26:03]
User341046 - Posts: 6
Tradingview recently introduced a nifty new feature.
Press Ctrl then spin MouseWheel to expand / contract candles at mouse pointer.
Currently if I want to expand candles, I have to first move the entire chart to the right THEN spin the mouse wheel to expand the candles. I have to rinse and repeat until I get the candles I am focused on expanded and centered the way I want.
Is there a Sierra Chart function/method available for this?
Thank you!
[2020-04-25 07:47:02]
We actually have this on our task list. We will try to get this done soon. Maybe over the weekend.
[2020-04-26 14:33:58]
This is now implemented. And will be out in version 2094 in about 20 minutes.
It does not work perfect under all cases. So it needs a little more work.
We did not yet test it with a scroll wheel. We just tested it using the up and down arrow keys to change spacing so it may not yet work with a scroll wheel. We may need to do some more implementation for that.
Date Time Of Last Edit: 2020-04-26 14:35:44
[2020-04-26 18:54:22]
Ok, so I upgraded. Opened a chart. Drew an ellipse in the middle of chart. Scrolled mouse wheel while pressing ControlKey. No change from previous behavior. I tried up/down arrows keys while pressing ControlKey. Same as previous behavior with/without pressing ControlKey. I am running Windows 10.
[2020-04-27 07:04:53]
It does need more work. Not sure why you did not notice the difference when using the arrow keys, but wait until the next release.
[2020-06-23 20:55:20]
User790545 - Posts: 41
Has this been integrated into the recent 2125 release?
[2020-06-24 04:40:17]
Yes refer to this setting:
General Settings Window: Scroll Wheel (Global Settings >> General Settings >> GUI >> Scroll)
