Date/Time: Thu, 06 Feb 2025 08:08:41 +0000
Dome price spacing
View Count: 830
[2020-04-21 16:38:20] |
PaulC - Posts: 16 |
in my dome the price spacings between ticks seem to be proportional to something but not equal. fail to find reason . can you help me determine what is causing that proportional spacing and restore it to equal spacing thanks. im using Ver 2088/64
[2020-04-21 23:50:35] |
So we can understand this, provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-21 23:50:42
[2020-04-22 12:58:32] |
PaulC - Posts: 16 |
http://www.sierrachart.com/image.php?Image=1587560052553.png HOPE THIS HELPS. NOTE VAROUS WIDTHS AND STEP INCREMENTS IN PRICESIN DOME |
[2020-04-22 13:34:33] |
PaulC - Posts: 16 |
FURTHER TO MY EARLIER POST, THE PROBLEM DISAPPEARED WHEN i REATTACHED THE dOME TO THE cHART
[2020-04-22 18:19:36] |
You need to use Auto Scale the Chart DOM: The Chart DOM Scale: Auto Scale the Chart DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
