Date/Time: Thu, 06 Feb 2025 09:54:25 +0000
locating a euro/usa market
View Count: 584
[2020-04-21 16:20:23] |
User149388 - Posts: 1 |
Hi, i have opened a demo account before starting trading. Not very familiar with forex. Being open litturally 24/7 on differentes markets world wide, how could i locate with your system what market are we looking at for the euro/usa plz? does it make sens ? S&p500: i know when i select it what market we are onto..etc..however forex i do not get it, could you help locate that? many thanks , and looking forward, best regards. |
[2020-04-21 18:10:38] |
Forex data in Sierra Chart is from FXCM. Refer to the information here: Sierra Chart Real Time and Historical Forex and CFD Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-21 18:10:58
[2020-04-23 02:39:53] |
User841513 - Posts: 15 |
Hello, is it possible to live trade on SC with an FXCM account? 2. Are brackets orders server held? |
[2020-04-23 10:34:56] |
It is really involved to get set up with FXCM and we do not prefer that. We recommend using LMAX instead and we also intend to add support for another Forex trading platform (ctrader) which is used by many brokers. For now, refer to LMAX: LMAX Trading Service 2. Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-24 03:03:27] |
Thank you. Problem is that I already have an FXCM account and also LMAX minimum funding is too high for me right now. Do you have an ETA for Ctrader support? |
[2020-04-24 03:28:39] |
It is hard for us to give a time estimate in regards to support for Ctrader. There are also some technical details that still have to be worked out which may make it not happen.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-24 03:29:03
