Date/Time: Thu, 06 Feb 2025 06:57:59 +0000
DOM Doubling the Stop/Targets When Filled on Simple/Multi Bracket Orders
View Count: 551
[2020-04-21 16:10:56] |
User245780 - Posts: 17 |
Hello Sierra Charts, I'm hoping you can help me with my DOM orders. I'm not sure what I'm doing wrong when setting up orders on the DOM. I'm trying to place 2 lot limit orders using both simple and multi bracket orders for MESMO. When I'm filled, the DOM shows the stops and targets doubled (4 stop and 4 target or 2 & 2 target). I set 2 for quantity. I select Simple bracket and check the Auto box. I set the stop loss and profit. I set the quantity for 2 for the multi bracket. I go into properties and set my exits for both of the lots and select 1 for lot size 1 and 1 for lot size 2. Grp-A is selected. I check the auto box. I tried both using the breakeven function by checking the 1st box and leaving them as zero unchecked. Your Assistance is Very Much Appreciated. Thank You, Date Time Of Last Edit: 2020-04-21 19:49:44
[2020-04-21 19:49:11] |
You are asking about the Transact trading software. This is not Sierra Chart. Please contact Transact about this.
