Date/Time: Thu, 06 Feb 2025 07:55:10 +0000
control bars and customized control bar in version 2086
View Count: 514
[2020-04-21 12:47:06]
AKR - Posts: 523
since I updeted to 2086 all the button descriptions in the properties of my customized control bar are gone and I have the original (long) name back in the buttons.
also "FS" has changed to "Find symbol", "OC" to open chartbook.
any way to get that back again, at least the standard control bars to shorter versions of description?
[2020-04-21 23:20:00]
You just have to manually set the shorter names for now:
Control Bar: Control Bar Button Properties
We plan to add an option to be able to use the short abbreviations as well.
