Date/Time: Thu, 06 Feb 2025 14:04:10 +0000
New daily candle not drawn with ICE US
View Count: 686
[2020-04-21 10:57:20]
Chris32 - Posts: 59
With symbols from ICE US : SB, CC, KC
I have never had this problem with CME symbols.
Every new daily candle is drawn like that (see attached chart)
http://www.sierrachart.com/image.php?Image=1587466039424.png
I have to manually either "Reload and Recalculate" or "Delete and Download Data" every day for each of these symbols to correct the glitch.
[2020-04-21 23:40:20]
Tell us the time and the time zone when that chart bar appears.
And when that happens provide us the last three lines from the Daily data file for the symbol. You can access that through Edit >> Edit Data-Historical Chart.
Date Time Of Last Edit: 2020-04-21 23:41:10
[2020-04-28 13:16:04]
Chris32 - Posts: 59
With OJ today : the bar appeared at the normal opening time (3PM Athens time zone)
Here are the three lines :
2020/04/23, 1.07849998, 1.09999998, 1.06749998, 1.07749998, 544, 6655
2020/04/24, 1.07749998, 1.09499998, 1.07699998, 1.08599998, 410, 6801
2020/04/27, 1.09099998, 1.12749997, 1.08999998, 1.12199997, 686, 0
The line for today only appeared after reloading the chart.
[2020-04-28 20:13:19]
Thank you. When you notice this, go to Window >> Current Quote Window. Do you see a Daily Open price there which is nonzero? And is also the last trade price nonzero?
[2020-04-30 12:13:18]
Chris32 - Posts: 59
The daily open is 0. The last price is non zero, it is correct. So are the other values.
[2020-05-01 03:47:29]
Okay we are going to monitor for this.
[2020-05-01 05:29:25]
We believe we found the problem. This should not continue to occur.
