Date/Time: Thu, 06 Feb 2025 07:46:39 +0000
.scid file is loading everytime I change the instrument
View Count: 578
[2020-04-21 10:32:16] |
jasongleamour - Posts: 25 |
Hi, Lets say that I am working in on EURUSD then I change the current chart to USDCAD. If I again want to change the current chart to EURUSD, I see Loading .scid file again. But I was just working on that chart, doesn't the program keep cache file and update it with new tick data? OR I have misconfigured something? Thanks |
[2020-04-21 23:38:18] |
The Intraday data file would be considered the local "cache". There is no re-downloading of data occurring. To improve performance, refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.12 - Intraday Data Storage Time Unit. Historical Data Record Time Frame. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-21 23:38:58
