Date/Time: Thu, 06 Feb 2025 08:01:52 +0000
Minimized windows disappears after screensaver or turning off monitor
View Count: 996
[2020-04-20 22:40:44] |
User128888 - Posts: 30 |
Hi, After coming back from screensaver (which turns off my monitor), the minimized windows disappear. The only way to get it back is to make the Sierra Chart window not full screen and then put Sierra back to full screen. Sierra is always set to full screen on one of my monitors. Attached is a screenshot of the issue. |
minimized-windows.png / V - Attached On 2020-04-20 22:39:37 UTC - Size: 43.01 KB - 259 views missing-minimized-windows.png / V - Attached On 2020-04-20 22:39:41 UTC - Size: 77.07 KB - 255 views Attachment Deleted. |
[2020-04-21 23:28:31] |
This is an operating system problem. It is not something Sierra Chart has any control over.
