Date/Time: Mon, 25 Nov 2024 04:44:26 +0000
Chart Linking Request
View Count: 1137
[2014-01-15 16:50:56] |
eagle - Posts: 92 |
After I have scrolled a chart I often use "Reset Bar Size/Spacing/Scale" to unscroll. If "Link Scroll Position" is active, then I have to reset each individual chart separately. Can you add a "Link Reset" option to "Chart Linking"? Or better still, when "Link Scroll Position" is active, can you keep the scroll positioning linked regardless of the method used to change the scroll position? Or maybe even do both . . . depending on your professional judgment of this issue. Thanks |
