Date/Time: Sat, 18 May 2024 08:16:29 +0000
Question on Order Type
View Count: 458
[2020-04-20 17:03:36] |
User745552 - Posts: 3 |
I'm newer and looking for which type of order to use in this scenario. There are so many and ive read the descritions but must be missing it. I want to for example short a mirco, set a stop 2 points above and a profit target of 4 points below for example all in one shot automatically when I hit the sell button, the opposite of course for buying, thanks for leading in the right direction, im sure i just missed it somewhere in the manual. Thanks.
[2020-04-20 19:20:03] |
What you are asking for is a simple Bracket order (order with Attached Orders). Refer to the following example which gives the information you are looking for. It doesn't matter if it is Long or Short, the Target and Stop will get placed properly: Attached Orders: Simple Bracket Example Also, be aware of Simulation mode where you can try these orders and see how they work: Trade Simulation: Using Trade Simulation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
