Date/Time: Sat, 18 May 2024 05:24:25 +0000
assign a conditional study sound alert to a control
View Count: 509
[2020-04-20 16:56:01] |
User970210 - Posts: 83 |
hi, it is possible to assign a conditional study sound alert to a control button? thx
[2020-04-21 02:12:16] |
If you are asking if you can just have the sound play when you select the Control Bar Button, the answer is No, this is not supported. If it is something else, could you please explain this more clearly what you need. There are control bar buttons available for Study Collections: Control Bar: Control Bar Study Collection Buttons and Keyboard Shortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-21 02:13:08
