Date/Time: Sat, 18 May 2024 05:24:26 +0000
32-bit version
View Count: 638
[2020-04-20 16:51:35] |
AC84142 - Posts: 9 |
HI I follow the prompt end up downloaded the 64 version ,how can i get only the 32bit thanks |
[2020-04-20 19:17:15] |
Both 32 and 64-bit versions are installed. You just need to go to the Sierra Chart folder in order to setup a shortcut and/or to run the 32-bit version. Refer to the information here: Software Download: Difference Between 32 and 64-bit Versions There may also be a shortcut installed for the 32-bit version already on the desktop. Also, be aware that sometime in the near future (we do not have a specific date yet), the 32-bit version will no longer be created, so if you need to upgrade hardware, you will want to take care of that soon. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-20 19:18:10
