Date/Time: Sat, 18 May 2024 04:54:36 +0000
[Locked] - 2 Instances and sim data for 2nd instance
View Count: 459
[2020-04-20 16:38:01] |
User587176 - Posts: 7 |
My understanding is If I want to try an autotrader in Sim and trade my other charts live I cannot set chart by chart to do this...Either all charts are in sim or all charts are in live. It seems i can accomplish by running 2 instances of Sierra? My questions are can I install a second instance with same login for Sierra and for the data? Or how can this be accomplished most efficiently/ Does Sierra have a real time sim feed? if you can point me to some instructional links it would be awesome. billy |
[2020-04-20 16:44:25] |
This is a repeat of the following thread: 2 instances questions This thread will be closed and any responses will be in the other one. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
