Date/Time: Sat, 18 May 2024 07:58:04 +0000
Percent Change Since Open issue v2088
View Count: 481
[2020-04-20 15:35:18] |
User796776 - Posts: 95 |
The Percent Change Since Open study changed in 2088, adding several new inputs. Without making any changes to the inputs, upgrading from v2083, the results achieved on v2088 appear incorrect. I have attached an image of the settings and charts showing the discrepancy. Date Time Of Last Edit: 2020-04-20 15:35:41
2020-04-20_11-17-33.png / V - Attached On 2020-04-20 15:35:31 UTC - Size: 131.01 KB - 230 views |
[2020-04-20 16:29:24] |
The problem is that the Time Period Length cannot be 0. Please remove the study, exit Sierra Chart, restart and then put the study back on as a new study. The default Length will be 1, do not change it to a 0. You should then have the same results with it set in this way. We will fix the study to not allow a 0 for that entry, and make sure that when the study is present from an upgrade, that it will default to a value of 1 if it is not already set properly. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-20 18:54:31
[2020-04-20 18:54:01] |
The reason the restart is mentioned is that the 0 value could cause an exception. But if you are not getting any exception no need to restart or remove the study. Instead simply set the Time Period Length Input to 1.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-20 18:54:25
