Date/Time: Sat, 18 May 2024 05:59:34 +0000
Sierra Chart with Advanced Features (Service Package 5)
View Count: 972
[2020-04-20 13:44:41] |
jasongleamour - Posts: 25 |
Hi, maybe the question is asked before but I would like to double check. If I purchase the above service, Forex real-time data and historical is included? Thanks |
[2020-04-20 15:53:52] |
Yes . Refer to: Sierra Chart Real Time and Historical Forex and CFD Data Service And refer to the information here for what Real-Time data is included with any package of Sierra Chart: Real-Time Data: What Real-Time Data is Directly Included with the Service Packages Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
