Date/Time: Thu, 06 Feb 2025 08:05:09 +0000
CQG data, IBKR routing
View Count: 1000
[2020-04-20 04:38:36]
User745789 - Posts: 356
Is it possible to have CQG data coming in, and order routing out via IBKR?
Asian exchanges. Stop gap solution while patiently waiting for local Asia Denali servers.
[2020-04-20 07:16:01]
Yes. This is explained here:
https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart
Date Time Of Last Edit: 2020-04-22 01:26:22
[2020-04-21 08:09:20]
Thank you. This page? Using Multiple Data and Trading Services at the Same Time
So I need to always run two instances:
Source instance gets data from CQG and shares it to Destination instance
Destination is set to route orders via IBKR.
To clarify: there is no way to stipulate separate data service, and trading service on a single instance? I am comfortable with two instances, just that over time the config settings tend to diverge.
[2020-04-21 23:27:11]
Here is the specific documentation again:
You do need separate installations of Sierra Chart.
Date Time Of Last Edit: 2020-04-22 01:26:38
[2020-04-22 01:13:51]
Thank you. However I am a little confused as to which page I should reference. From the one you link, bold mine:
If you want to use multiple copies of Sierra Chart with different Data and Trading services, then refer to the Using Multiple Data and Trading services page instead of the instructions on this page below.
[2020-04-22 01:27:06]
We apologize, we actually posted the wrong link. We accessed the wrong link on the page. This is the correct one:
