Date/Time: Tue, 29 Sep 2026 03:06:40 +0000
delayed reply
View Count: 868
[2020-04-19 18:46:16]
MarcOh - Posts: 176
Hey guys,
is there any way to fix the difference price between TPO and renko in the reply mode?
I didnt change the speed, or did any other changes while the reply and did read the whole documentation.
Thx a lot!
imageScreenshot_2.jpg / V - Attached On 2020-04-19 18:46:06 UTC - Size: 274.03 KB - 369 views
[2020-04-19 22:43:29]
We need to understand this better. First make sure the Session Times of either chart are not filtering out the current Date Time being replayed. Refer to:
Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.3 - Session Start Time and End Time not Covering Current Time
Is this just a case where there sometimes is a difference when you pause the replay? This is hard to avoid because each chart uses its own separate timing variables. And if there is a lot of price movement at the time of pausing, the prices could be different between charts.
Date Time Of Last Edit: 2020-04-19 22:44:21
[2020-04-26 05:34:43]
MarcOh - Posts: 176
Hey,
sorry for late response. For everyone with this problem:
Fixed it in the gloabal settings- data trade service- set "time zone" to which you use. In my case "new york"
Thx a lot one more time! sometimes you should give yourself a little more time to regulate things.
marc
Date Time Of Last Edit: 2020-04-26 05:38:05
[2020-04-26 09:15:50]
Is this a case where there are different time zones among the replaying charts?
If they are different, we will solve this problem.
Date Time Of Last Edit: 2020-04-26 10:01:24
