Date/Time: Sat, 18 May 2024 05:59:35 +0000
Chart Value Window
View Count: 432
[2020-04-19 15:18:22] |
User483657 - Posts: 1 |
How do get the chart value window to open for previous days not just the current session?
[2020-04-20 07:31:05] |
You need to use the Tool Values Window: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
