Date/Time: Sat, 18 May 2024 04:37:19 +0000
Three Line Break Chart Setup
View Count: 1460
[2020-04-19 11:18:37] |
User268057 - Posts: 2 |
Hello, I've upgraded to the latest release, and need to set up a chart with the 3 Line Break setup. I've been searching on the How-To, but haven't found a step by step instruction set. I'm a new sierra charts user, with little to no experience... I thank everyone in advanced for your help on this matter. Joseph |
[2020-04-19 13:17:05] |
Ackin - Posts: 1865 |
Try: 1] Menu >> Analysis >> Studies 2] Find study "Three Line Break Chart" in study list 3] Select it and use the "Add" button to move it to the right window 4] "Apply" |
[2020-04-19 13:19:44] |
For "Three Line break Support/Resistance Lines" Look at: Three Line break Support/Resistance Lines |
[2020-04-20 04:47:48] |
We want to point out that the Three Line Break Chart study in Sierra Chart is older and has not been rebuilt as a proper low-level built-in bar type. It does not work properly during a bar based back test. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-20 07:08:08] |
Sierra Chart Engineering) Thanks for the information. Will be this study in the studies list also in the future? |
