Date/Time: Thu, 06 Feb 2025 06:38:30 +0000
Chart Setup
View Count: 521
[2020-04-19 05:51:41]
Eric - Posts: 21
Hi, how do I view this part of the chart?
The only way I can do that is to adjust the scale on the right side. But it will make all the bars very short and can't see the details of the bars.
If I choose to use the "hand" and move to the top, I still won't able to view as the chart itself sets a boundary to where I can go.
Also, I'm using numbers bar but since the product I'm looking at, HSI futures has too many price levels, the numbers bar show too many numbers in a bar. Is there any way I can combine say 5 price levels so that it shows the volume for 5 combined price levels?
Thanks a lot
imageIMG_20200419_134111.jpg / V - Attached On 2020-04-19 05:44:25 UTC - Size: 207.53 KB - 188 views
[2020-04-19 10:06:56]
Refer to these two sections:
Numbers Bars: Adjusting Tick Size For Larger Increment (Adjusting Tick Size For Larger Increment)
Numbers Bars: Scaling a Numbers Bars Chart
