Date/Time: Sat, 18 May 2024 07:24:53 +0000
Is there a study that displays your current total monetary position?
View Count: 447
[2020-04-19 01:33:21] |
User807787 - Posts: 41 |
I want to be able to easily see my current total monetary position. ie. The sum $ of all current active trades(Share size * Fill price) Is there a study I was unable to find that can display or collect this? Or do I have to custom build one and use the Text display study? Cheers |
[2020-04-20 07:29:46] |
This is not supported. You would have to create a custom study to do this . A custom study can access all of the positions that are currently open.
