Date/Time: Thu, 06 Feb 2025 07:16:18 +0000
Quote Board not updating properly in 2086
View Count: 630
[2020-04-18 19:18:38] |
denarius - Posts: 16 |
I was using 2057 and had no problems. At request of broker I upgraded to 2086: Quote Boards are now not showing accurate highs, lows, volume, and daily range etc. Instead of showing that information from the start of the futures trading day (from 6 PM ET) regardless of time of day I start up Sierra Charts, the Quote Boards are now showing the data only from the moment I start up Sierra Charts so if I start up Sierra Charts at 7 AM ET, high/low/volume/daily range etc reflect only what happens from 7 AM ET onward and not from 6 PM ET - they are missing 13 hours of market activity. this never happened in any version from 2057 and earlier.
[2020-04-19 01:11:32] |
You are using Transact. Refer to this section here: https://www.sierrachart.com/index.php?page=doc/TransAct.php#AccessingMarketDepthDataAndDailySessionValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
