Date/Time: Thu, 06 Feb 2025 06:45:38 +0000
Copying dll files to a new instance
View Count: 503
[2020-04-17 22:04:34] |
User910795 - Posts: 35 |
I am trying to effectively copy some dll files from my main instance to a second instance and have these run properly (as they do in the main instance already). My understanding is that I should be able to copy these files from the data folder in the main instance and paste them into the data folder in the second instance and things will work, but they do not. Do I have to do this in logged in as "administrator" in order for it to work, and if so (I feel dumb saying this) how do I log in as administrator? I have copied these files successfully in the past, but just can't seem to get it to work this time and logging in as administrator may make a difference |
[2020-04-18 01:05:54] |
Yes your understanding is correct. And you do not need to be logged in as Administrator. Maybe the issue has to do with 32-bit versus 64-bit compatibility: How to Use an Advanced Custom Study or a Study Collection: Custom Study Not Listed or Not Displaying on Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
