Date/Time: Thu, 06 Feb 2025 15:01:12 +0000
Question on Pulling & Stacking (user email)
View Count: 646
[2020-04-17 19:56:52] |
SC Support - Posts: 1927 |
Please see the attachment: how can you have 201 offers stacked but only have 9 on the offer? Unless there this some accumulation count then there is some issue. Thank you |
[2020-04-19 01:05:42] |
What data feed is this being noticed with? We have observed this at times.We are not completely sure of the cause but the only solution we can think of is just not to make any adjustment of the pulling and stacking values, when there are trades. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-04 01:41:47] |
Denali is the Data Feed Pre-release 2093 still showing Pulling & Stacking Column greater than offer column |
[2020-05-04 01:45:58] |
Not sure that this issue was resolved in that version. Please update to prerelease 2099: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-04 01:46:36
