Date/Time: Thu, 06 Feb 2025 06:48:24 +0000
Connection Hold Up
View Count: 489
[2020-04-17 15:22:40] |
JayShea - Posts: 92 |
Hello Normally I have Sierra on 24/7. Windows did an update last night requiring complete shutdown and startup. I had v.2083 and attempted to install v.2086. I was told it was installed with errors. When I attempt to access the account I'm told "Invalid Account Name or Password". I have an account with Transact (for over a month now) and I put in my Username and Password with Transact but I get the Invalid message. Help please. JD Schaefer jdrows |
[2020-04-17 16:14:37] |
You need to login with your Sierra Chart Account Name and Password: Sierra Chart - Software Login Instructions: Software Login Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
